Oil pressure falls at higher rpm.
Old Sep 6, 2005 | 11:26 AM
wlz28's Avatar
How do I stop it???? 1st through 3rd is when it does it. 4th and up it stays fairly steady.
Old Sep 6, 2005 | 01:55 PM
blackz97's Avatar
Re: Oil pressure falls at higher rpm.
What kind of oil pan are you using on your motor? Does it have a windage tray? It sounds like you may have some cavitation at higher RPMs.
Steve
Old Sep 6, 2005 | 02:05 PM
SStrokerAce's Avatar
yeap what steve said
Old Sep 6, 2005 | 02:33 PM
wlz28's Avatar
stock pan, no windage tray
Old Sep 6, 2005 | 04:02 PM
blackz97's Avatar
You may want to invest in an aftermarket oil pan. One that has a built in windage tray. Canton comes to mind. If i recall correctly they have a windage tray and i think also a crank scraper (a windage tray at the very least). Its a high capacity unit as well that holds more oil then the stock on which can sometimes compliment built motors that see a lot of time in the upper rpm range.
Steve
Old Sep 6, 2005 | 04:13 PM
amean94ta's Avatar
trap doors is what you want
Old Sep 7, 2005 | 08:36 AM
wlz28's Avatar
But I've seen plenty of strokers running the factory pan with no problems
Old Sep 7, 2005 | 10:56 AM
Yeah but YOUR problem is that you have absolutely no windage tray in there..... you really think GM would waste the couple of cents per motor to put something it in that didn't need to be there. Your problem is becuase you don't have some sort of windage tray.... you need to fix that unless you don't mind replacing bearings and rebuilding the motor.
Bret
Old Sep 7, 2005 | 12:24 PM
BADST95's Avatar
Smile Re: Oil pressure falls at higher rpm.
What type of oil filter are you using?
Old Sep 7, 2005 | 12:34 PM
1racerdude's Avatar
Ya don't know what has been done to the inside to promote oil control.
This kind of statement always get's me as most that make the statement's have never seen the inside and presume it is just like it is out of the box.
If out of the box "stock" would work people would not be having all the trouble with oil pressure and rebuilding the engine after a few miles.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
