Oil pressure drops at WOT
Old Mar 13, 2006 | 09:58 AM
  #16
CMANZ28's Avatar
Re: Oil pressure drops at WOT
Here are two past threads about this......
http://web.camaross.com/forums/showt...ght=cavitation
http://web.camaross.com/forums/showt...hreadid=209526
Old Mar 13, 2006 | 10:28 AM
  #17
crAzy95z28's Avatar
but this makes me wonder if im going to starve the engine?
kinda like a motorcycle, when u pop a wheely, the oil doesnt go into the engine, gets stuck in the back of the pan!
Old Mar 13, 2006 | 10:35 AM
  #18
jsetzer's Avatar
Mine: Stock melling pump, Canton pan, canton pickup (bolts to pump), extra baffle between pump/pickup. I have 60psi @ wot all the time. This is with the stock 60psi spring.
Friends: Aftermarket stock size pan, melling SV pump, oil pressure drops at WOT.
Same bottom ends, almost identical motor builds. Machine work done by the same builder.
Old Mar 13, 2006 | 10:47 AM
  #19
crAzy95z28's Avatar
but why would it do it after 900 miles or after my dynotune?
it never did it before.
Old Mar 13, 2006 | 10:54 AM
  #20
atljar's Avatar
Ive been fighting this for months too.
383, milodon 7 QT pan with windage trey, HV pump
Changed between like 5 different weights of oil, and many different filters. The Wix racing (1060R) helped alot, and I thought I had the issue fixed. My car didnt have a bypass valve on it.
Fast forward to new SR cam, and the problem comes up again. I was using brand new Wix Racing filter. I also tried reinstalling the bypass valve. Still reverse oil pressure up top.
Next week I will re-clearance the pump and install a rear pan baffle. Will update everyone.
Old Mar 13, 2006 | 10:56 AM
  #21
crAzy95z28's Avatar
i also have a damn fram filter..
but i doubt thatd fix it!
Old Mar 13, 2006 | 11:07 AM
  #22
atljar's Avatar
Never know until you try.
The Wix filter I mentioned above is available from NAPA. Its about $13 and is a 1qt. If your car is oil cooler equipped, it will need to be removed.
Speaking of oil coolers, if any of you have one, try taking it off too. Back in the day i gained a ton of pressure by removing it
Old Mar 13, 2006 | 11:14 AM
  #23
crAzy95z28's Avatar
hmm oil cooler. DOnt think i have one.
but would i have to drain the oil to replace the filter or could i just take off the old filter, fill up new one and replace?
Old Mar 13, 2006 | 11:24 AM
  #24
atljar's Avatar
You can just unscrew the old filter, fill the filter with fresh oil, and screw it on again.
Old Mar 13, 2006 | 11:30 AM
  #25
crAzy95z28's Avatar
thank you!
Old Mar 13, 2006 | 11:53 AM
  #26
crAzy95z28's Avatar
how can u tell if it has a oil cooler and where would it be at?
Old Mar 13, 2006 | 05:25 PM
  #27
atljar's Avatar
The oil cooler mounts above the oil filter and has coolant lines running to it.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
