Oil Pressure dropped? Check gauges light
Old Apr 14, 2005 | 11:48 AM
blind527's Avatar
After me and my girlfriend were leaving Baltimore, we were driving it in the city and I floored it past this person doing like 15 MPH. When I got to the light my oil pressure was all the way at 0 and my check gauges light came on. A little freaked out, I put the car in neutral and it went back up. What could have caused this?
Old Apr 14, 2005 | 01:17 PM
atljar's Avatar
Re: Oil Pressure dropped? Check gauges light
Could have sucked the pan dry (is it low at all on oil)?
Old Apr 14, 2005 | 01:18 PM
big dave's Avatar
check your oil level. Also could possibly be a faulty sending unit.
Old Apr 14, 2005 | 01:21 PM
matLT1's Avatar
Did you brake very hard? sometimes that can cause oil to rush away from the pump for a moment. As mentioned above you can check the sending unit too.
Old Apr 14, 2005 | 01:48 PM
blind527's Avatar
I just did an oil change like 700 miles ago, it's full of oil. How can/do I check the sending unit? I didn't brake THAT hard, or I don't think I did, it's happened to me a couple of times though.
Old Apr 14, 2005 | 03:22 PM
atljar's Avatar
If it happens often when you brake it also could be the pan pickup has fallen off. Drain the pan, knock on the bottom of it and see if you hear it rattle around.
Old Apr 14, 2005 | 03:24 PM
blind527's Avatar
What if I DO hear it rattling around? What would I need to replace?
Old Apr 14, 2005 | 06:35 PM
pearlpurple's Avatar
I have experienced the same thing and asked about the oil pick up. Was told on this board that if my oil pick up fell off I would get no oil pressure,,, is this true?
Old Apr 15, 2005 | 10:21 AM
INSTG8R's Avatar
If you do hear it rattling around, which it sounds like that might be your problem, you need to drop the oil pan. I suggest buying a bracket that bolts to the pump and holds the pickup tube on. I had this happen on my car and I ordered the bracket from JEGS. Some people have welded the pickup tube on but I would just buy the bracket. Good Luck!
Old Apr 15, 2005 | 10:27 AM
INSTG8R's Avatar
You would have pressure until the oil level dropped below the pump, or in the lower rpm's. Without the pickup on, the pressure will drop as soon as the oil level drops below where the pump itself can pickup the oil without the tube on. When mine fell off, I had pressure until the rpm's started climbing above 3500, then the pressure would start to fall off pretty rapidly.
Old Apr 15, 2005 | 04:14 PM
thanks for the reply,,, with mine (not trying to high jack but hoping to get answers and add to this thread) I can go up through the rpms medium to hard acceleration and no problem, but a hard stomp from a stop or slow roll and wham down to zero oil pressure. What could that be.
My normal pressure is 20 - 25 idles and 50 - 55 highway
Old Jun 5, 2005 | 12:48 PM
blind527's Avatar
I drained the oil pan and I didn't have any rattling noises. Is the sending unit the wire attached to the oil pan right by the oil drain plug?
^^ My car does the same thing at times. Usually when I stomp on it as well.
Old Jun 5, 2005 | 12:52 PM
Z28Nut's Avatar
The sensor in the side of the pan is the low oil level sensor. The oil pressure sensor is on the side of the block, pass. side IIRC.
HectorM52
Jul 30, 2017 11:46 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
