oil pressure droping
Old Feb 3, 2005 | 07:27 PM
red 95 z28 lt1's Avatar
just recentley did a le2 package and when i start the car when its cold i get about 40 psi. but then when it warms up a little bit it goes to 20 and then it slowley drops to the redline. when it gets warmer or running temp the check gauges light comes on and i have like almost no oil press but when i rev it it goes to like 25 psi. i have a really low idle when its warmed up i still need a tune and bigger injectors. im also running open y pipe if this helps. i dont know whats going on. before i did the heads and cam swap i had no problems. oil press was 20 at idle and 40 above idle. im running 20 w 50 non synthetic oil.
Old Feb 3, 2005 | 07:29 PM
hsyr's Avatar
Re: oil pressure droping
My want to start saving for a new shortblock
Old Feb 3, 2005 | 07:46 PM
StickMaster's Avatar
have someone sit in the car and watch the guage whilst you pop the hood and wiggle the oil pressure sending unit (on the back of the intake) if it moves around a bit that may be your problem ~25 bux i think.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
