oil pressure check with mech gauge question..
Old Aug 2, 2007 | 07:23 PM
mobleman's Avatar
I'm in the process of checking my oil pressure with a mechanical gauge as I type (Idling and warming up in the driveway) IP gauge drops to about 15 psi when the car warms up on warm days, and this is a newly rebuilt motor with only 1900 miles on it so far..
Anyhow back to my question: With my cam, should the mechanical gauge be bouncing around at idle? It's currently at 40 psi but the needle is bouncing around in step with the cam lope... Idling at around 800 to 1000 rpm (m6) Is this what one would expect?
Old Aug 2, 2007 | 07:40 PM
mobleman's Avatar
Just got done running it around.. results with mechanical gauge:
Cold Idle: 45 psi
Warm Idle, before driving: 25 psi
Warm idle after driving 15 minutes: 18 psi
Driving:
2000 rpm: 40 psi
3000 rpm: 48 to 50 psi..
Thinking I'm ok here, just hate the fact that the warm idle drops so low..
any thoughts on the jumpy needle at idle?
Old Aug 2, 2007 | 10:12 PM
If the idle fluctuates 200 RPM, it might jump a little. The next question is what did you use for a pump?
Old Aug 3, 2007 | 05:56 AM
mobleman's Avatar
Builder put in (I believe) a Melling OEM Replacement pump (not High Volume)
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
