Deleting Traction Control Questions???
Old Aug 2, 2007 | 10:39 AM
97 6SPEED Z's Avatar
Question Deleting Traction Control Questions???
I have the '97 Z28 M6 shown in the signiture below with traction control. I'm finally getting to the point where I'm thinking of deleting traction control, so I can get rid of that TC motor/control box which sits atop my driver's side valve cover.
First off, does anyone have a procedure written for deleting this option without setting any SES and/or ABS IN OP lights? And, secondly, shoebox's web site says I need the GM P/N 12554852 ('97 non-TC) cable to delete this, but both my local GM dealer and GM Parts Direct don't carry this anymore. Where can I get this cable?
TIA for all replies!
Old Aug 2, 2007 | 11:50 AM
1SlowFormula's Avatar
I'm not sure if or how the 97 might be different from my 95, but I pulled my TCS and Cruise Control at the same time and just replaced the throttle cable with one from a non-TCS car, I got mine through Dal (sorry don't have the PN here at work)...
I can't see the dealerships or parts houses not having this because there were soo many f-bodies without TCS, since it was optional, what happens if they break the throttle cable? I would call Dal and see what he can do...
*** EDIT ***
I was wrong, I did have the PN of the cable I used on my work machine, I guess I do more car stuff at work then I thought...
12550676 is what I got, and according to this post on tech it is for 94-96, not sure why 97 needs a different cable???
Old Aug 2, 2007 | 10:52 PM
Unhappy
1SlowFormula, I am not sure either why '97 LT1's show a different GM part number for the non TCS throttle cable, but, my problem still exists......I can't find a GM dealer that still carries these.
I called another local Chevy dealer here today, and also e-mailed "customer service" at GM Parts Direct. It appears GM just stopped making these????
Anyone know any GM or aftermarket sources for these?
Again, TIA for all replies.
Old Aug 2, 2007 | 10:56 PM
dangalla's Avatar
i just got mine last week, pn 12550676
they had to order it but i got it in like a day, they def have it
Old Aug 2, 2007 | 11:07 PM
Unhappy
Dangalla, GM P/N 12550676 is supposed to be the non TCS throttle cable for '94-'96 LT1's. Both parts guys at the two(2) Chevy dealerships I've talked to so far have told me GM P/N 12554852 is the correct non TCS cable for the '97's, but they also say GM doesn't supply them anymore??????
Anyway, does your P/N 12550676 cable work okay on your '97???
Old Aug 2, 2007 | 11:09 PM
dangalla's Avatar
dont know yet, motor is not in the car, will be in like aweek but i am sure you will know by then, sorry i could not help anymore
Old Aug 3, 2007 | 09:06 AM
Thumbs up
Okay, GM Parts Direct does have the P/N 12550676 non TCS throttle cable for '94-'96 LT1 Camaro's (Thanks dangalla, and 1SlowFormula!). Does anyone know what changed in '97 to make GM put out the P/N 12554852 non TCS throttle cable, and more importantly, can the '94-'96 cable be modified, (if possible?), to make it work on a '97 LT1????
TIA for any more info on this.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
