oil pressure always high
Old Jul 13, 2011 | 04:23 AM
aknight_sa's Avatar
my oil pressure gauge is always showing above max pressure on the gauge, it only goes down before i turn the engine on!
yesterday i disconnected the cable from the sender unit and it still shows max pressure..
is the problem from the gauge itself? is there a way to fix it?
have a 97 Camaro with LT1 engine
Old Jul 13, 2011 | 05:03 AM
Guest47904's Avatar
Guest
Re: oil pressure always high
Break in the signal wire somewhere.
Old Jul 13, 2011 | 10:56 AM
aknight_sa's Avatar
here's a video of it
http://www.youtube.com/watch?v=h3yvEZR05yk
Old Jul 13, 2011 | 11:11 AM
RamAir95TA's Avatar
What speedy said is correct, which should give you a pretty good indication on where to start.
Old Jul 13, 2011 | 11:22 AM
LS1Z28's Avatar
If you unplug it with the engine off key on and the gauge maxes out it's the sending unit.
Old Jul 13, 2011 | 12:42 PM
aknight_sa's Avatar
i unplugged it with engine off key off...need to start tracing the cables
Old Jul 13, 2011 | 04:47 PM
Guest47904's Avatar
Guest
If it's plugged in and maxes out and when it's not plugged in it maxes out, wouldn't that indicate the wire is not making connection?????????
Old Jul 13, 2011 | 05:07 PM
bw_hunter's Avatar
Grounding the signal wire should yield zero on the gauge. If it doesn't zero out it's the wiring. If it does it's the sender......
Simple as that
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
