Aftermarket Balancer for 388 Stroker
Old Jul 12, 2011 | 08:57 PM
spilner's Avatar
Building a 388 stroker and need a good balancer
Any good balancers out there besides the ati balancer? Its a little to steep for me to spend on a balancer.
Certain one I should steer clear from?
Thanks guys
Old Jul 12, 2011 | 09:08 PM
RamAir95TA's Avatar
Re: Aftermarket Balancer for 388 Stroker
Having a good balancer/damper is definitely a worthwhile investment. There's a reason everyone used the ATI or equivalent.
Old Jul 12, 2011 | 09:12 PM
spilner's Avatar
would you ever run a used ATI? Obviusouly if it looked ok not banged up lol
Old Jul 12, 2011 | 09:19 PM
RamAir95TA's Avatar
As a matter of fact, the one on my motor was used, so yes.
If you're still concerned, ATIs can be rebuilt.
Old Jul 12, 2011 | 09:23 PM
95mysticta's Avatar
Running ATI that i got used an well worth the money.
Old Jul 12, 2011 | 09:42 PM
spilner's Avatar
Thanks guys. Guess I will be checkin classifieds everyday lol
I got about 2 weeks before I am ready to bolt it on so hopefully one pops up for a fair price.
Thanks again
Old Jul 13, 2011 | 01:05 AM
lymlyt96's Avatar
If price is an issue professional products has a damper thats pretty good and you can get it for about $250 from summit the powerforce plus can spin safely up to 10,000rpms and the regular powerforce up to 6500 I believe and that one is much cheaper I've seen those on ebay brand new for just over $100 you can call up either summit or professional products and they can let you know which one would be best for your application. Just giving you options this is the same damper im using for my motor now and was recommended by my engine builder.
Old Jul 13, 2011 | 08:45 AM
spilner's Avatar
yeah I saw that profesional products one. If I cant find a deal on the ati that could be another option. Im thinking my motor will be turning atleast 7k rpm so may need the more expensive one.
Thanks man
Old Jul 13, 2011 | 11:53 AM
importkiller94's Avatar
Whatever u go with make sure it has a key slot if there is a key on ur stroker crank. My stock crank did not have a key so I had to buy the ATI damper when I put the stroker crank in. The ATI damper does have the key slot
Old Jul 13, 2011 | 08:31 PM
MachinistOne's Avatar
Stay away from that Professional Products Chinese crap, way too many instances of those blowing apart at speed. If you need a good quality damper on a budget you should get a Pioneer (Powerbond) SFI unit.
HibachiZ28
Nov 6, 2015 12:53 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
