Oil Pressure for a 128k mile lt1 m6
Old Jun 5, 2008 | 09:25 AM
94YellowTAGT's Avatar
After some other threads about oil pressure i wanted to ask my own.
My 94 ta is showing about 25 on the pressure gauge at 1600rpm in 6th gear. Is this fine or a sign of trouble. On start up it is around the middle of the gauge but slowing goes down to 25 or so.
Thanks,
Old Jun 5, 2008 | 11:20 AM
seawolf06's Avatar
25psi is fine. I think you want a min of 15psi running hot and an increase of about 10psi for every 1000RPM.
If you haven't removed the oil cooler, it is highly recommended that you do asap.
Old Jun 5, 2008 | 11:21 AM
I haven't removed the oil cooler yet. I just heard about that. I will read into it. Should you remove it or can i buy a replacement one that would work better?
Old Jun 5, 2008 | 11:26 AM
Dadic 78's Avatar
Can you explain the importance of removing the oil cooler? I haven't removed mine, and I'm around the same mileage...
Old Jun 5, 2008 | 12:29 PM
8cylinders>4's Avatar
running 10w30 oil at 112,000 miles i see about 30-35 psi at 1600 rpm fully warmed up
i have also heard of people removing their coolers, but i thought it was the style of cooler that came on 96-97 LT1's i thought they were a little different internally and easier to plug up with crud, but the earlier coolers were ok
can anyone elaborate?
Old Jun 5, 2008 | 12:36 PM
If it helps i run 10w-30 Mobil 1. I have for about 25k miles.
Old Jun 5, 2008 | 01:08 PM
slomarao's Avatar
the oil coolers use coolant in the rad. to warm up the oil during and after start up. *I think*. I do know that they easily clog up and removing them usually results in more pressure.
The 94-95 cars had a better design i understand but still, after time they will clog. I dont think the 93 cars came with them.
If you search around you will find plenty of threads about removing it.
Old Jun 5, 2008 | 01:16 PM
Could this be a cause of a coolant leak i can't find anywhere? It hits the ground well behind were the hose are.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
