Oil pressure 0-15psi any ideas?
Old Mar 13, 2008 | 12:15 AM
  #16
thebignickey's Avatar
it looks good to me. as far as oil leaking around the intake
Old Mar 13, 2008 | 11:52 AM
  #17
Z-ROC28's Avatar
I just bought a 97 SS two weeks ago also. My oil pressure guage is doing the same thing. I've read several times on LS1tech that our cars just normally have a low idle pressure and it is nothing to worry about. My guage needle also jumps like a clock hand does. Does yours do that also?
Old Mar 13, 2008 | 12:08 PM
  #18
Originally Posted by jer4251
check the back or front of your intake for oil. id just run your hand around where you cant see. if oil is leaking, wouldnt it cause a loss of pressure?
That oil is not under pressure and should cause no pressure loss.
Old Mar 13, 2008 | 12:50 PM
  #19
Pro_built7's Avatar
exactly.
Old Mar 13, 2008 | 01:18 PM
  #20
JohnD's Avatar
I just put a new one on Sat. with the white thread compound not the tape, that stuff will screw an engine up way to fast. No oil back there. keep the suggestions coming guys.
You did right but for the wrong reason. Tape around sensor threads won't hurt an engine but it can keep the sensor from grounding and working correctly.
Old Mar 14, 2008 | 05:57 PM
  #21
it does not jump around it is reading as it should. the oil pressure i have is not normal no car should be running around with it that low i got the car to my buddy's shop yesterday and we will be tearing into it on Monday. so i will keep you all posted. There is no metal in the filter but there are a few small pieces of gasket, so there might be a chance that the oil pump screen is just clogged up.
Old Mar 25, 2008 | 08:47 AM
  #22
Angry Its not the pump
Well I got the new pump in what a pain that was,and after all that work I still have the same oil pressure so a short block is being built as I type this. I am not to happy with this fact as I just bought the car not but a few weeks back and was told it was just the gauge.
Old Mar 25, 2008 | 01:10 PM
  #23
caldercay's Avatar
My gauge has *always* run low on idle. When I trashed the oil
pressure sensor (new tranny/etc), I thought, "great, with a new
oil pressure sensor, I should see better readings on the gauge".
Rwong. It still reads the same. 150k+ miles, 10/40 Royal Purple.
I've had people tell me their gauges read the same. Of course,
I'd be concerned about 4psi on idle - I'll have to check where
exactly mine hovers.
And while we're complaining, my gas gauge is wacky. When I
fill up, the needle goes past 'F' and points straight up 12 oclock.
And at some point, around 1/4 tank, the needle drops from about
1/2 tank to 1/4 (which is accurate).
Old Mar 25, 2008 | 04:42 PM
  #24
Its not the fact that my gauge reads low it is the fact that "I DO HAVE LOW OIL PRESSURE"
If the gauge was wrong I could care less thats why I bought the car in the first place. I did not care if the gauge was the way it was but when you actually have low oil pressure thats another story. I drive 500 miles from school to home and back all the time I cant have my car breaking down in the middle of no where on the way back home or to school. Or on the way to class for that matter.
Old Mar 25, 2008 | 05:21 PM
  #25
Ironxcross's Avatar
Originally Posted by BAMF
**** it! my car has 60psi when its cold but when it warms up its at like at 15-45 while driving around 155,000 miles stock motor and a 150 shot- still strong.
yeah.. thats how my oil pressure is too. it starts stupid high and runs normally around 40
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
