oil pressure @ 20psi at idle??
Old Jul 24, 2003 | 01:22 PM
JuiSSed's Avatar
is this normal? i just rebuilt a 355 LT1.. broke it in with 10w40.. now it has 1000 miles and just used Mobil 1 5w30.. just seems kinda low.. what is everyone else's pressure at idle??
thanks
vinnie
Old Jul 24, 2003 | 01:27 PM
oldBones's Avatar
mine at about 900 rpms sits on 20psi
Old Jul 24, 2003 | 01:34 PM
BUBBA's Avatar
I just put Mobil 1 5W30 and a K&N filter on having just reached the first 500 miles on a new short block (broken in with dino oil).
Before the change, I was seeing around 40 at idle and between 40 and 60 at cruise.
Now I am seeing around 25-30 at idle and it goes up over 40 when RPM goes up.
Appears that the Synthetic oil and high perf. oil filter has an affects pressure, however I don't have a clue as to what a proper reading is supposed to be.
Just understand that the sensor is supposed to read between 15 and 80 OHMs.
Old Jul 24, 2003 | 01:41 PM
JuiSSed's Avatar
thanks for the inputs..
with 850rpm at idle it's about 20psi, but it moves up to 40-50 under gas..
thanks
vinnie
Old Jul 24, 2003 | 01:53 PM
grygst76's Avatar
the thinner the oil, the less pressure you will see. Also synthetics have a tendency for you to see less pressure.
Old Jul 24, 2003 | 03:36 PM
Derrick Redd's Avatar
Mine is about 20 psi at idle when hot. Goes to 55 psi at WOT. I'm using 10w30 Royal Purple.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
Cam's maro
Mar 24, 2015 08:09 PM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
