Oil plugs behind timing chain
Old Nov 8, 2005 | 11:06 PM
hallbilly's Avatar
im trying to find where to get these little babies. Dont know exactly what they are called. they are .5' and are supposed to have a certian size hole for oil to pass through to the timing chain.... or so i read on a few post a long time ago. I cant really find it in the old post. Probably just looking over it
Old Nov 9, 2005 | 12:13 AM
Re: Oil plugs behind timing chain
Gm Part # 10110897
Old Nov 9, 2005 | 05:58 AM
cehan's Avatar
If you get aftermarket plugs that aren't drilled, you can drill them yourself. The hole should be 0.030", but when I did it I used a #70 drill bit which is 0.028" and probably close enough.
Chris
Old Nov 9, 2005 | 07:13 AM
hallbilly's Avatar
Thanks fellas!
Old Nov 13, 2006 | 12:16 PM
FASTFATBOY's Avatar
Back from the dead.
WHich plug do you drill, does it matter?
David
Old Aug 11, 2007 | 06:33 PM
bdc95ta's Avatar
Back from the dead again, David did you ever figure out which one is suposed to be drill? I just looked at mine and none of them are drilled, I'm really regreting my engine builder, shouldn't he have done this for me?
-b
Old Aug 11, 2007 | 06:35 PM
wrd1972's Avatar
Make him do it.
Old Aug 11, 2007 | 06:46 PM
bdc95ta's Avatar
It's already in the car, the guy didn't clean the paint off the cam (which could of cloged up all kinds of stuff), or even clearance the valvecovers for the promags, or hit the compression ratio I wanted, didn't have the machine shop zero deck the block now my quench is a little on the high side, I just flat out don't trust him and would rather do it myself.
-b
Old Aug 11, 2007 | 06:47 PM
bdc95ta's Avatar
The more stuff I check the more upset I get. But at least I'm checking, and it will be perfect one day....
-b
Old Aug 12, 2007 | 10:27 AM
JP95ZM6's Avatar
Holes go in the two outside ones, not the middle one. Buy an extra bit while you are there. I drilled mine (threaded plugs) off the car - some do it on the car, but I would be afraid of breaking a bit and getting it or shavings in the motor.
Old Aug 12, 2007 | 10:43 AM
chevyowner02's Avatar
Chris
I used a 1/64 bit now I am thinking mine are to big might have to buy some new ones.
Old Aug 12, 2007 | 11:01 AM
JP95ZM6's Avatar
1/64"? 1 / 64 = 0.015625. Too small, not too big.
Folks say .030, but the .028 bit wouldn't even fit in my stock ones, so IMO even drilling .028 is increasing it slightly. I did .028.
Old Aug 12, 2007 | 11:26 AM
Boosted_Z28's Avatar
Lt-1's use these oils to add a little extra oiling to the top of the timing set to help lubricate the water pump gear. A lot of rebuilds don't include the oil holes and noboby seems to be incuring any problems from the lack of a little extra oiling. If the motor is apart it certainly won't hurt anything to drill a .020" - .030" hole in each of the side plugs. I would also have to presume that they get pluged over time with sludge on some of the high mileage motors when oil changes are neglected.
Old Aug 12, 2007 | 12:53 PM
bdc95ta's Avatar
Hmm..interesting. Thanks for the info guys I apreciate it.
-b
Old Aug 13, 2007 | 05:47 AM
cehan's Avatar
The way I determined the 0.028' was by trying different drill bits from my #61-80 drill bit set until I got to one that fit snugly in the holes; that turned out to be #70 which is 0.028".
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
