Oil pan thread size at sensor
Old Sep 7, 2006 | 05:29 PM
bingo's Avatar
Does anyone know the thread size for the low oil sensor in the pan? I don't need this sensor and I want to delete it because it is leaking. I could probably use an oil plug if I could find the thread size.
Old Sep 8, 2006 | 07:31 AM
97WS6SCharged's Avatar
Re: Oil pan thread size at sensor
I believe it's 20m x 1.5. You can order a plug from Canton Racing Products. PN #22-405
Old Sep 8, 2006 | 08:38 AM
droptop z's Avatar
I would just get a new gasket, you'll probably end up buyin the gasket anyway to install the new plug.
Old Sep 8, 2006 | 03:21 PM
bingo's Avatar
The sensor is useless in my car since I don't have an oil light. I also don't like the idea of a plastic sensor(that has broken off in other peoples engines) in my oil pan. I am building a new engine and I am just going to delete it. Thank you for the reply on thread size.
Old Sep 8, 2006 | 03:34 PM
Dave89IROC's Avatar
alot of them leak through the sensor, not at the threads
Old Sep 8, 2006 | 08:32 PM
bingo's Avatar
I went and checked Canton's site and that is the size they listed as well. I went to the parts store and bought an oil plug that size. It was about $3. Thanks to those that helped.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
