Oil Pan problem. Need help.
Old May 27, 2003 | 07:39 AM
RealQuick's Avatar
Well, I cracked my oil pan last night and oil pissed out everywhere. I am about to do heads and Jet Hot LT's, but now I'll have to do oil pan as well. I might get the Canton oil pan or stock replacement. Is it possible to get the stock oil pan out without pulling the motor. Also, are there any fit problems with the Canton pan that anyone knows of? Need advice on this. Is this gonna be a disasterous job?
Old May 27, 2003 | 07:41 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Oil Pan problem. Need help.
you can take the stock one off by just pulling the starter and jacking the motor up a few inches and fiddling around
Old May 27, 2003 | 08:16 AM
RealQuick's Avatar
Thanks Trey.
Anyone know of any fit problems with the canton oil pan with an M6 tranny, or LT's, or any other possibile problem.
Old May 27, 2003 | 08:32 AM
Xscream's Avatar
the Canton pan will fit with LT's but its a squeeze.
Old May 27, 2003 | 09:06 AM
RealQuick's Avatar
Which long tubes are they a tight squeeze on
Old May 27, 2003 | 09:57 AM
PoorMan's Avatar
May want to call nutek or cmotorsports. One of those companies sells the canton pan with modifcations to fit the LT1 better.
Jeff D.
Old May 27, 2003 | 10:26 AM
RealQuick's Avatar
Jeff D.
Jeff, thanks for the heads up on Nu-tek. Their pan is modified for Hooker longtubes and they sell a pretty good kit. How hard is it to replace the pickup and oil pump?
Old May 27, 2003 | 10:54 AM
Xscream's Avatar
It was a tight fit with the Hookers and the TPIS headers. Its not that big of a deal, just tight working quarters. You have to do the pickup when you do the pan if I recall. It is a piece of cake to do it while the pan is off.
Old May 27, 2003 | 11:00 AM
RealQuick's Avatar
Cool. What about the actual pump. Is that tough to get at?
Old May 27, 2003 | 03:00 PM
Xscream's Avatar
Its not a bad idea but isn't big deal if you don't. I would just becuase I am down there but its quite rare that the oil pump will just fail by it self.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
