oil pan Needed for 355?
Old Mar 21, 2005 | 04:11 PM
Mystic97Z's Avatar
my oil pan is trashed after a connecting rod went through it, doing a 355 setup, i know i don't need an after market (ex: moroso) for the sake of clearence, but will i need a bigger capacity for the sake of not loosing oil pressure at high rpms?
also, will a 6 or 7 qt pan hang down lower that a stock one? car is lowered.
thanks
-Jason
Old Mar 22, 2005 | 12:45 PM
Re: oil pan Needed for 355?
I've seen the stock pan and stock pump support an 1,125HP LT1 running to 8,000+rpm redline. A stock pan will be fine.
Old Mar 22, 2005 | 12:54 PM
JAG05's Avatar
Not trying to steal the tread or anything, but were is this 1,125 hp LT1?
Old Mar 22, 2005 | 01:11 PM
96m6lt1's Avatar
i am thinkin that it is the twin turbo Lt1,injuneer is usually 100% on the money with knowledge.
Old Mar 22, 2005 | 01:17 PM
1-bad-z28's Avatar
Originally Posted by Mystic97Z
doing a 355 setup, but will i need a bigger capacity for the sake of not loosing oil pressure at high rpms? -Jason
nope
Old Mar 22, 2005 | 03:36 PM
Right here:
http://cjcfo.fbody.com/members/injun.../DCP02600z.jpg
George Baxter's 30th SS convertible, 1,125 flywheelHP from a 381 running a Vortech S/C with 20+ # of boost, heavily worked Canfield heads, Hooker LT's, 8,000rpm solid roller, Art Carr TH400, Moser 9-inch, MoTeC ECU. Ran 9.04@155mph at a 3,900# race weight, and for almost 2 years (2000-2002) was the quickest known LT1.
Eventually the car ran 8.60@160, but that was with a Gen 1 SBC 383 w/ Vortech S/C.
Old Mar 22, 2005 | 05:41 PM
94zgreenmachine's Avatar
Right here:
Injuneer
Your like an encyclopedia with all the info, I learned some stuff off the post about injectors vs. fuel pressure good thing there are guys like you around on the board
Old Mar 22, 2005 | 07:29 PM
SAR2K's Avatar
...will i need a bigger capacity for the sake of not loosing oil pressure at high rpms?
No.
Old Mar 22, 2005 | 11:58 PM
Originally Posted by 94zgreenmachine
Injuneer
I just happen to be friends with George, and know almost as much as he knows about the car.... .
Old Mar 23, 2005 | 12:17 AM
97 RedSS's Avatar
I still have my stock oil pan I pulled off when I went to my Canton since I went with a 383...let me know if your interested...
Cody
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
