Oil Pan Interchangability
Old Sep 28, 2005 | 04:18 PM
2000GTP's Avatar
Will an oil pan off of a 93 LT-1 work on a 97 LT-1. Is there any differences with the oil pressure sending unit? Or will it matter considering I will be swapping the oil pressure sending unit from my 97 pan onto the 93?
Old Sep 28, 2005 | 05:25 PM
OBE1 95Z28's Avatar
Re: Oil Pan Interchangability
Oil pressure sending unit is mounted on top of the block just below the EGR valve. The oil level sensor is mounted in the pan. Not sure if the pans are different or not.
Old Sep 28, 2005 | 07:05 PM
1racerdude's Avatar
Pan will fit but use your low oil sender. They should be the same but never tried it.
Old Sep 28, 2005 | 11:11 PM
2000GTP's Avatar
I looked up the part #s on shoebox's site and they are the same. Thanks for the replies.
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Jul 5, 2015 03:27 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
