Which oil pan gasket to use?
Old Mar 30, 2007 | 03:36 PM
kgkern01's Avatar
Going to replace my oil pump with a Melling 10% HV pump and the GM HP 70 psi spring. What oil pan gasket do I need to get for the easiest and leak free install?
Old Mar 30, 2007 | 03:42 PM
OBE1 95Z28's Avatar
Both the stock GM and the FelPro gaskets are nice pieces. I prefer the FelPro as it has molded in spacers to keep you from over tightening the oil pan nuts.
Old Mar 30, 2007 | 03:58 PM
LiENUS's Avatar
I hate when my nuts are too tight. My fel-pro gasket also came with little blue plastic snappy thingies to hold the pan on while i put the bolts in and started them.
Old Mar 30, 2007 | 07:28 PM
396D1SS's Avatar
i always like using fel pro as well
Old Mar 30, 2007 | 07:35 PM
mdacton's Avatar
you are not using a HV pump on a stock pan are you?
Old Mar 30, 2007 | 08:39 PM
kgkern01's Avatar
Just a 10% HV pump, not the usual 25% HV pumps that people use and end up sucking the pan dry. With 150k miles, I figure that it would be good insurance with the slightly extra volume and the high pressure spring.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
