Oil Pan Gasket Question?
Old Jun 15, 2006 | 11:20 AM
nb 96 z's Avatar
How long does it take to swap out the oil pan gasket and what parts do I have to remove to get to it? I have an oil leak where the gasket is in between the oil pan and front cover. Thanks.
Old Jun 15, 2006 | 12:12 PM
Sweetred95ta's Avatar
Re: Oil Pan Gasket Question?
From what I've heard, you have to take the motor mounts loose and raise the engine up. Then, drop the pan down (it will only come down like a couple of inches at most) then put the gasket on. I think you have to cut the gasket. I'm not sure though.
Old Jun 15, 2006 | 05:09 PM
PoorMan's Avatar
I tore my gasket taking the timing cover off during my cam swap. I replaced it with a felpro and did not have to do anything but drop the pan. It will only drop an inch or so but it's enough to install it. You will need to use a wrench and a racket to get to all the bolts. I also had my headers, starter, and oil filter off btw. I do not know if they would interfer or not with them on. I placed a rag over the steering rack so as not to get dirt on the gasket.
Before:
http://community.webshots.com/photo/...44372733HuTkSW
After:
http://community.webshots.com/photo/...44372733ncxlEM
Old Jun 15, 2006 | 05:13 PM
Kevin Blown 95 TA's Avatar
As stated above, just drop the pan and you can fish it under. Not fun, and it's hard to keep everything clean, but definately doable w/o messin with engine mounts or anything else. Also once did it with my cam swap - that's a good time to do it cause you need to drop the pan to get the timing cover off.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
