Oil pan gasket
Old Sep 4, 2007 | 02:15 PM
raroz28's Avatar
Oil pan gasket
I just pulled the Y pipe, starter, and the shield between tranny and starter, and all the bolts from the pan.
Used an impact gun to get the nuts off the motor mount through bolts.
I can't get the bolts out though. They're in there pretty good. One of them is almost all the way out, and the other is only about 1/2" out.
Is there a secret? I don't have a cherry picker yet, I'm borrowing a friends so it's gonna be about another 2 hours before I get it, but I can't seem to get those bolts out. I'm thinking I'm gonna hook up the picker and jack up the motor and try to pull the bolts while I jack it up.
Workin' on your back sure does suck. I can't wait to get this job done.
Old Sep 4, 2007 | 02:26 PM
NemesisLT1's Avatar
im sure working on your knee's might 'suck' a little more
Old Sep 4, 2007 | 08:20 PM
raroz28's Avatar
I said screw it and just put the gasket on w/out pulling the pan. Much quicker that way.
Old Sep 4, 2007 | 10:44 PM
Irish350's Avatar
i jacked up the engine from the pan and propped it up with 2x4s, then pulled/replaced the gasket with the pan by slipping it through the bottom.. dirty, but it works.
Old Sep 4, 2007 | 11:29 PM
raroz28's Avatar
Well, I wasn't going to jack by the crank pulley. That seems like a lotta weight for the aluminum bearings in the rods and mains.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
