oil level SENSOR
Old Jun 2, 2011 | 01:04 PM
NJ-LE's Avatar
oil level SENSOR
My oil LEVEL sensor has started leaking ... anything special about removing it with the pan still on the engine? What are people using to plug the port if the switch can't be sealed?
Old Jun 2, 2011 | 03:33 PM
Re: oil level SENSOR
M20 x1.5 bolt with sealing washer to replace the sensor. 15-20 mm long should work.
Because it is long, pull the sensor straight out, so you don't break any of it off inside the pan.
Old Jun 2, 2011 | 05:19 PM
NJ-LE's Avatar
Thanks for the timely and complete info.
Old Jun 2, 2011 | 09:40 PM
z275plus's Avatar
Where can I find that size bolt.
Old Jun 2, 2011 | 09:54 PM
Depends on what you have locally. NAPA would be a good place to start. They might have a drain plug that size.
Old Jun 5, 2011 | 04:01 AM
97WS6SCharged's Avatar
Canton sells a plug if you can't find one locally. Or you can take the sensor out and weld it shut like I did.
Old Jun 6, 2011 | 06:17 PM
NJ-LE's Avatar
I found an M20-1.5 oil drain plug in the hardware drawers at the local LOWES!! $2.98
Old Jun 12, 2011 | 12:37 AM
kylersaulsbury's Avatar
why not just put a new o-ring on it and call it good?
Old Jun 12, 2011 | 03:33 AM
bw_hunter's Avatar
They almost always leak through the body of the sensor. They're plastic and not terribly rugged
HectorM52
Jul 30, 2017 11:46 AM
captcorvette
Mar 7, 2015 12:37 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
