Oil Level?.. 5Qts Shows Way Overfull??
Old Aug 4, 2008 | 12:30 PM
ENRKyle20's Avatar
Alldata says to put 5 qt in when changing filter. I put 5 qts in and it the stick says its about an inch over the full line. I have ran the engine to fill the filter. This reading was taken after I let the oil drip down over night, but thats when it should be perfect.
Its a stock pan. Only modification is a few small spots I had to beat on to clearence it for the longer stroke. I am using a diffrent dip stick. My car didnt have one when I bought it, so I purchased one used from someone on here. I think it was from a TA and im using it on a Z28. I bet thats the problem. Are they diffrent legnth?.. I am still using the Z28 tube. can some one give me a measurment of the tube and the stick?..
Old Aug 4, 2008 | 12:38 PM
camarozz95's Avatar
The stick not including the handle just the metal stick is 24.5in hope that helps.
Old Aug 4, 2008 | 07:28 PM
My Red 93Z-28's Avatar
I thought the LT1 only used 4.5 qts.
Old Aug 4, 2008 | 08:13 PM
ENRKyle20's Avatar
hmm. I did a search and some people say 4.5, others 4.75, some say 5. hmm. now im confused. maybe I should just trust the stick?
Old Aug 4, 2008 | 08:21 PM
The Engineer's Avatar
I bet you have the wrong dip-stick (too long). 1/2 quart would not be an inch on the dip-stick.
WD
Old Aug 4, 2008 | 08:22 PM
ENRKyle20's Avatar
so should my stick be 24.5"?
Old Aug 4, 2008 | 08:38 PM
WD
Congrats on the mention in GMHTP!
/hijack
Old Aug 4, 2008 | 09:41 PM
lt1-xjs's Avatar
Mine takes 6 qts. with the M1-302 filter to bring it to the full mark.
Old Aug 4, 2008 | 10:29 PM
I guess the filter I use is pretty short
Old Aug 5, 2008 | 10:36 AM
Severous01's Avatar
check the pan for dents...maybe someone 'missed' the frame when jacking the front up...and while you're at it, check the exhaust too...it's right there as well.
Old Aug 5, 2008 | 10:39 AM
ENRKyle20's Avatar
there is a few little dents, but when I clearenced the pan for the longer stroker I just took a big deadblow and bowed the whole area out. that should have made it be able to hold more. maybe not by much.. but it would make up for any small dents. I think its just the wrong dipstick. I will do an oil change and see how much it takes to get it to full. if its under 4.5qts then I know its wrong.
Old Aug 5, 2008 | 07:36 PM
z28camaro1090's Avatar
I had the same problem the first oil change i did i was told 5qts and it was way overfilled.. next time i went to pep boys and they said 4qts what their computer said this time it was perfect
Old Aug 5, 2008 | 08:18 PM
ENRKyle20's Avatar
wow.. thats sad. a big V8 taking less oil that a BMW inline 6.. by almost half..
anyway. I put 4 qts and started the engnie and it was still over by about 1.4 inch..
I am having a little leakage from between the block and bell housing. telling me that is the rear main, or one of the gally plugs. since the plugs and threaded and I put thread sealer on them I dont think its that. I guess it could be the large plug for the cam.. but still unlikly.. I think its the rear main. I have inspected closly and its not coming from the valve covers or heads at all, the back of the block is clean. I was thinking if its overfilled it could come out the rear main maybe, its not ment to hold oil like a waterfall, its never submirged in oil unless is way overful. but I put 4 in and it still leaked so its not that. I may just have to remove the tranny AgAiN.. and see where its coming from..
I would definatly like to get this whole oil thing figured out. Did we decided if the TA and camaro stick or tube are the same>?.
Old Aug 5, 2008 | 08:52 PM
maverickmk's Avatar
dip stick and tube is motor/oil pan specific, not model specific
Old Aug 5, 2008 | 09:47 PM
SS RRR's Avatar
Originally Posted by ENRKyle20
wow.. thats sad. a big V8 taking less oil that a BMW inline 6.. by almost half...
There are reasons for that. Those engines have many many more oil passages and moving parts than your standard SBC. The V6 in the new Camaro requires over 7 quarts...
