Oil leaks *PICS*
Old Jul 31, 2003 | 06:43 PM
NVetro's Avatar
Oil leaks *PICS*
Hey all what do you make of these 2 pics?
This is of front of the motor, where is the oil coming from?
http://www.webideas.net/misc%20art/fronttiming.gif
This is from back of the motor with the flywheel, etc.. off, rear main seal was done 6k ago, and does it look like oil pan is leaking?
http://www.webideas.net/misc%20art/rearmain.gif
tell me what u think.
Old Jul 31, 2003 | 07:01 PM
1msfyter's Avatar
How many miles on your car? I think just about everyones LT1 leaks oil in the front by the timing cover. Mine does , but not enough to leave any oil on the floor. I dont worry about it I wipe it down every 4-6 months. But I have no oil oil leaks or burning.
Old Jul 31, 2003 | 07:03 PM
96speed's Avatar
Easy fix: Opti and front main seals that are pressed in the timing cover.
harder fix: Oil pan gasket.
Its VERY likely one of those 3 seals.
Ryan
Old Jul 31, 2003 | 07:04 PM
Rodrigues's Avatar
Its probably a seal on the timing chain cover, chances are its the WP seal.
Old Jul 31, 2003 | 07:05 PM
Terran2k's Avatar
yeah mine recently started to leak from there too, not enough to drip on the floor. not going to go crazy about it right now.
Old Jul 31, 2003 | 07:08 PM
joeSS97's Avatar
I looked at the pics,cant tell exactly where it is.Has to be either the crank seal,opti seal,or water pump drive seal.All i can say is get all those seals and replace them.
Old Jul 31, 2003 | 07:12 PM
NVetro's Avatar
thanks for input all, the 2nd pic is the rear of the motor with the trans, etc.. out. Oil pan looks moist, the rear main seal was done 6k miles ago, does it look moist enough that its leaking? The car has 103k miles on it. Oil pan it a PITA, i know. I am starting to think now, that its NOT my rear intake manifold.
Old Jul 31, 2003 | 07:19 PM
NVetro's Avatar
Try this pic, rear of motor, what is leaking? the rear main seal done 6k ago, car = 103k, oil pan?
http://www.webideas.net/misc%20art/rearmotor.gif
Old Jul 31, 2003 | 07:38 PM
NVetro's Avatar
any other ideas? We established its the timing cover thats leaking, as for the rear, is it the rearmain seal or oil pan?
Old Jul 31, 2003 | 07:55 PM
Speed Addiction's Avatar
My guess would be that the oil is leaking right at the corner of your oil pan, next to the rear main seal. Chevrolets are notorious for leaking there if precaution isn't taken while putting the oil pan on. Gotta make sure to pull that corner down real good when bolting the pan down.
Old Jul 31, 2003 | 07:59 PM
NVetro's Avatar
hmmmm....whats best way to drop the oil pan?
Old Jul 31, 2003 | 08:16 PM
NVetro's Avatar
There looks to be NOTHING wrong with the rear main seal, why is it moist with oil? It was done 6k ago, is there a speical way to remove it/install it? Post away, i wll replace this one and somehow get the pan down.
Old Jul 31, 2003 | 09:17 PM
Keep in mind, it is easy for a leak at the front of the engine to migrate toward the rear because of air flow. The only way I find to pinpoint leaks is to thoroughly clean the area, drive it and recheck the locations.
Old Jul 31, 2003 | 09:51 PM
NVetro's Avatar
The car is jacked up, i see the moist spots on the oil pan (rear) and the rear main seal. I wipe is clean and i can literaly see it start to get moist agian. Dealer said they replaced the rear main seal, maybe they didnt, hmmm.
Old Jul 31, 2003 | 10:26 PM
94GrayV6's Avatar
I can tell just by looking at your rear main that it's dry, that isn't your problem.
