Oil leak under the timing chain cover....
Old Apr 30, 2006 | 09:42 PM
wrd1972's Avatar
Got a small oil leak in the front of the oil pan right under the timing chain cover. Again its a small leak.
I checked the two front bolts, they are tight.
Any ideas for fixing this without having to replace the oil pan gasket?
Can I pack some grey RTV on it?
Old Apr 30, 2006 | 11:26 PM
ibanez6rg's Avatar
Re: Oil leak under the timing chain cover....
You could try some RTV for a temporary fix.
Old May 1, 2006 | 06:33 AM
chrism400's Avatar
Clean it off really well with brake cleaner and then rtv it up. There's no pressure on it so if you get it to seal, it will last a while like the above post says. I did it that way after the cam install 2 yrs ago. It's still holding.
Old May 1, 2006 | 07:22 AM
Javier97Z28's Avatar
Moderator
Or even a semi-permanent fix, mine held up for 3 years
Old Sep 1, 2006 | 10:37 PM
shady_ws6's Avatar
Looks like I have the same issue... I just had a cam install done, and now I see a leak starting at the bottom of the timing chain cover....
Is it true to just clean it really good, then RTV it?
I'd appreciate any input!
Thanks!
Old Sep 1, 2006 | 10:57 PM
OBE1 95Z28's Avatar
Are you sure it's the oil pan that's leaking? The waterpump drive seal is a common leak and it druels down the front of the timing chain cover.
Old Sep 2, 2006 | 09:29 AM
shady_ws6's Avatar
well I put an electric water pump on.... so I guess thats a possibility... I'll get under there today & try to pin point it.
artic94
Jan 17, 2015 11:19 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
