Oil leak on top of valve covers
Old Aug 12, 2009 | 02:42 AM
RallyBoy1's Avatar
I have an oil leak on top of my valve covers at the bolt holes and the filler neck. I modified them to fit my pro-mag roller rockers using golen's website. I do not have any puffing out of the filler neck or dipstick. I have changed the pcv valve. What else could it be?
Old Aug 12, 2009 | 05:17 PM
Kevin Blown 95 TA's Avatar
Maybe you could get some sealing washers in a similar size to the aluminum washers the stock bolts use. sealing washers have a rubber seal on the inside portion of them just like the ones that are used for the back of the heads and steam lines or some that have rubber on the bottom of them.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
