Oil leak from Opti?????
Old Nov 28, 2003 | 05:32 PM
S.J.S.'s Avatar
Hey guys.....like everyone knows, got my stroker in about 2 weeks ago. I recently found an oil leak from my timing chain cover. Can't exactly locate the leak but it looks like its coming from behind the Opti. Anyone have this problem?? Or where else could it be leaking from???
Old Nov 28, 2003 | 05:39 PM
Kataklysm's Avatar
My timing chain cover is leaking as well, looks to me like its coming right from the gasket.
Old Nov 28, 2003 | 05:52 PM
JDBlaze85's Avatar
if its a 96-97 Lt1, then yeah possibly the seal behind the opti is bad and leakin. no big deal, just have to pull the opti off and im sure you can change out the seal without taking the timing cover off.
Old Nov 28, 2003 | 06:49 PM
Red_94Formula's Avatar
this is very common. its the seal but not the seal that is leaking but where the seal is pressed in is where the leak is. yes what i just said suxs. all aftermarket opti seals do this and i bet you put in a new seal like rest of us and me for insurence. take the seal out and simply use rtv around the edges when you put it back in. then put some over the edge once it is installed and BAMM! no leak.
Old Nov 28, 2003 | 06:58 PM
S.J.S.'s Avatar
I'm assuming your talking about where the seal connects to the timing cover. So put RTV on the outside also???? How do you change the seal without taking off the timing cover......oh yeah I remember, it pops off from the outside. okay thanks guys, I'll try that.
Old Nov 28, 2003 | 07:40 PM
Buttercup's Avatar
The most common leak point on the timing cover is the waterpump drive shaft seal. Nine times out of ten that seal gets rolled when installing the timing cover. I always take extreme care with that seal. If it leaks it will run down the front of the cover exiting below the opti.
If you have an electric waterpump this becomes a non-issue of course and installing the timing cover becomes much, much easier.
Old Nov 28, 2003 | 11:28 PM
S.J.S.'s Avatar
Anyone else experience this problem?? Will it get worse. I just threw my motor in and it runs great. To bad this had to happen. I knew it was too good to be true.
Old Nov 28, 2003 | 11:42 PM
JDBlaze85's Avatar
yeah it sucks
just suck it up and pull the timing cover off and put a gasket set on it. change all the seals and the gasket on the cover so you can forget about it. a couple of bucks...........just get ur hands dirty.
Old Nov 28, 2003 | 11:47 PM
FastZinTennessee's Avatar
heh, I put my motor back together and have the exact same problem. I really don't feel like messing with it, so my car leaks oil now, and will continue to do so until I fix it(whenever that may be)
Old Dec 1, 2003 | 12:10 AM
S.J.S.'s Avatar
Originally posted by JDBlaze85
yeah it sucks
dude, I just built this whole motor and dropped it in a few weeks ago. I aint worried about getting my hand dirty. I just wanna know because if its the Opti seal, I'm sure I can do it without pulling the cover...which means I don't have to drop the pan. Anyone else???????
Old Dec 1, 2003 | 12:14 AM
Van5150's Avatar
Oh great, the EXXON Valdeeze has now run aground on the main island. Killing all sorts of wildlife and plants and things.
Just another reason to support the S.J.S.383-Ban.
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
