OIL LEAK, need help!!
IM leaking oil. It is deffentally from the passenger side of the motor. Ive checked the intake manifold and it seems ok, but is by no means rulled out as an option.
After a 30 min drive i could hear something, im going to assume it was oil, hitting something hot, probably the y-pipe.
Im thinking maybe valve cover(crossing fingers), anybody have any other options.
Thanks.
Car has 46,xxx miles, oil is redline 10-w30
Thanks.
Re: OIL LEAK, need help!!
Thanks.
Thanks.
How do I check the rear main seal??
Originally posted by Smoke T/A
It's very unlikey your rear main is leaking unless it has been disturbed before. You would have to drop the tranny to check it.
Im going to check things again, but i have a feeling its actually the manifold.
As far as i know the rear main has never been touched, but ive only had the car for a year, so i cant say for certain. I figgured i would have to drop the tranny to check. But the more i think about it, the less likely it seems that it could be the rear main, do soley to the fact i heard oil hitting the exhaust system last night.
Originally posted by Tech
Did you just change your oil? You may have two gaskets on your oil filter.
THanks.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
