Oil leak (Front of oil pan)
Old Sep 13, 2004 | 09:24 AM
southern78's Avatar
Its a new seal. It drips oil every time I stop. Just drops several drops and then stops. Not sure why it leaks.
Old Sep 13, 2004 | 11:20 PM
Lt1t56's Avatar
Re: Oil leak (Front of oil pan)
Brake cleaner or carb cleaner can be your friend, clean it good and then drive it look where leak is coming from. Front engine oil leaks can be from pan, water pump drive seal, opti seal, crank seal or front of intake.
Old Sep 15, 2004 | 07:07 PM
southern78's Avatar
Yup, its a intake leak. Bought the new gasket and all today.
Old Sep 16, 2004 | 05:27 AM
slopokrodrigez's Avatar
Don't waste your time with those cork thing a ma bobs. Put some black permatex on the front and the back and be done with it for good. We always have problems with the cork crap but never when replaced with Permatex.
Old Sep 16, 2004 | 08:31 AM
southern78's Avatar
Would some High temp red RV stuff work ok to? I have a tube of that already.
Old Sep 18, 2004 | 09:00 PM
Only the black permatex is the way to go. It has a different texture and consistancy. It's the bomb.
Old Sep 18, 2004 | 10:10 PM
indieaz's Avatar
When i swaqpped the cam out in my car i ripped the front of the oil pan gasket, made a new one out of copper RTV. Worked great. Now when i rebuilt the engine i wanted it to look nicer so i used a new oil pan gasket (plus i had two brand new ones here so why not)...well guess what now i have a leak from the front of the oil pan Sometime i need to jack the engine up a few inches and drop the pan and put some RTV in there or something.
Old Sep 19, 2004 | 12:10 AM
southern78's Avatar
Used the red stuff worked fine. no leaks sense. It has a higher tolerance then the black stuff that came with it. But just had tube of it around. Made some scratch marks liberally on the front and abck and wasn;t stingy with the red high temp RTV. So far so good and pleased.
Magenta_Hearts
Mar 29, 2017 08:54 PM
artic94
Jan 17, 2015 11:19 AM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
