Oil Leak Front of Engine
Old May 19, 2004 | 07:52 PM
Greg94Z's Avatar
I already fixed the intake leak this winter and now I am leaking oil again but from the front of the engine now. What are the most likely causes of this leak? It is mostly wet around the crank but has splashed all around the bottom front.
Old May 19, 2004 | 08:07 PM
2FNFAST's Avatar
I have the same problem and was also wondering.
Old May 19, 2004 | 08:13 PM
RCF925's Avatar
waterpump seal or the opti seal on the front cover.
Old May 19, 2004 | 08:31 PM
Valkyn71's Avatar
Timing cover, i have the same thing
its a bitch to get the cover on right.
DAM OIL PAN GASKET
Old May 19, 2004 | 09:05 PM
camaro325's Avatar
I got the same problem
but I don't think it leaks enough to fix it, it's very very minor
Old May 19, 2004 | 09:24 PM
Clean up the area and then check it regularly, so that you can determine just what is leaking.
Old May 20, 2004 | 11:36 PM
OBE1 95Z28's Avatar
I've used dye that is added to the oil and used with a black light. You can see the opti and crank areas fairly easy. The waterpump seal is tough to see but is a likely candidate if you've replaced the timing cover.
artic94
Jan 17, 2015 11:19 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
