oil leak from the front
Old Nov 4, 2005 | 03:32 PM
badasschevy625's Avatar
hey i want to say that it is the front seal crank seal does this usally go out and if so how hard is it to replace does anyone know where any tutorials may be i really want to get it fixed up.
Old Nov 4, 2005 | 07:05 PM
matt65's Avatar
Re: oil leak from the front
My front crank seal was leaking, pretty easy to replace. I know a lot of people have a hard time with the balancer. Honestly my biggest trouble was out to the new seal itself. It took many many tries to get it to go in.
I used a small pic to remove the old seal, pretty easy.
Old Nov 4, 2005 | 07:54 PM
OBE1 95Z28's Avatar
It's best to be sure where the leak is coming from before you start changing seals. There's 4 seals on the front that can leak: crank seal, opti seal, waterpump driveshaft seal and the timing cover seal. From my experience the waterpump driveshaft seal is the usual culprit. Your can buy a dye that is added to your oil and will show up under black light. Clean the front of your engine, add the dye and see if you can find the source of your leak.
Old Nov 28, 2005 | 05:52 PM
v6wells's Avatar
hello
Old Nov 28, 2005 | 06:16 PM
Guest47904's Avatar
Guest
If it is a seal, why don't you try either high mileage oil or try adding Lucas oil treatment. Both have extra swelling agent in them to help seal leaky seals. I prefer valvoline max life myself. Never know, could help save you from doing a job that sucks.
Magenta_Hearts
Mar 29, 2017 08:54 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
