Oil leak after headers and timing install
Old Mar 25, 2008 | 06:16 PM
PWR-TRIP's Avatar
My car has developed an oil leak after i did the headers and timing chain set. The leak is from the middle
Anyone gone through this before?
Old Mar 25, 2008 | 06:40 PM
dangalla's Avatar
your gonna have to be a little more specific than that
get under the car and try to trace the oil to the highest point
Old Mar 25, 2008 | 06:43 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
From the middle of what?
My guess would be one, or more, seals in the timing cover. They're kind of in the middle.
Old Mar 25, 2008 | 07:28 PM
PWR-TRIP's Avatar
Thats what i was thinking too.
F#ck i don't want to open her up again.
Old Mar 25, 2008 | 07:45 PM
BTC's Avatar
BTC
If it's a seal in the timing cover, it should be fairly easy to detect from under the car. After I replaced my opti, the water pump drive seal was leaking like a ****. It was pretty easy to detect that at least one of the seals was leaking by laying under the car with the engine running. Oil was streaming down the front of the timing cover.
Old Mar 25, 2008 | 07:47 PM
ssclone's Avatar
could be oill pan gasket.
could be timing cover seal, or front main seal leaking.
get under it and look, thats what i would do. oil is like water, its not usually leaking from where you think it is. you have to trace it.
aaron
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
