Oil Leak 95 Z
Old Mar 12, 2011 | 05:46 PM
jlew69's Avatar
Oil Leak 95 Z
Hi, I've had an oil leak for awhile now. Replaced the valve cover gasket twice on the passengerside. I'm cleaned the bottom of the car and started it, didn't notice a leak, but after sitting for a couple of days after driving there is a 3" circle of oil on the passengerside. Most of the oil is over the starter and on the header. I don't feel oil behind the intake or under the valve cover. Oil pan bolts are tight, and the rear main looks ok. I can smell burnt oil when I drive the car, and notice smoke from from the passengerside right at the door and fender area. Any suggestions will be greatly appreciated.
Old Mar 12, 2011 | 10:14 PM
JBirdSS's Avatar
Re: Oil Leak 95 Z
mine leaked at the back of the intake manifold. Seems to be a common place for leaks in the LT1.
Old Mar 14, 2011 | 07:36 AM
jlew69's Avatar
Re: Oil Leak 95 Z
Thanks, I'm going to put some paper towels back behind the intake. I can't feel any oil back there. But it comming from some place. Getting worse. Any sensors back of the intake that could be leaking?
Old Mar 14, 2011 | 10:49 AM
JBirdSS's Avatar
Re: Oil Leak 95 Z
everything you will need is on shoebox's tech page. shbox.com
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
