Oil Leak
Old May 10, 2008 | 01:22 PM
z28desire's Avatar
Oil Leak
Ok so i redid the intake gasket because that was my first thought. It wasnt that, its not the valve covers and as best as i can tell its not the rear main seal. I took the inspection plate off and there is no oil on the flywheel or converter. So my question is what are the other possibilities? Also the oil seems to be almost everywhere from the tunnel back. Its on the firewall and on top of the bellhousing and everything in between. Thanks
Old May 10, 2008 | 01:57 PM
rcantrellz28's Avatar
You have a 93, so check to see if the pressure sensor is the culprit or , in my case , it was my oil level sensor making a mess. It took me a while to figure out where it was coming from, but my mess was caused by that, I believe yours is the same as a 95 ( level-sensor) which is on the side of your oil pan. Your pressure sensor on a 93 is located differently than mine:http://shbox.com/1/oil_pressure_sensor.jpg. They do make a dye that I have never used, but you may want to give it a try,its cramped as hell under there, and hard to see Good Luck.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
