Oil LEak?
Old Oct 1, 2004 | 08:42 PM
budvol's Avatar
Oil LEak?
I have an oil leak...
While its running... u can smell it and at nite u can see smoke stiring around the headlights.
But if it sits overnight there are only about 3 or 4 drops.
But if u look under the car u can see oil from the front back..
Someone put in a water pump i think and it looks like a crapy job. I cant pin it down where its coming from. I dont think it a rear seal
Could it be comung from the timing chain cover?
Old Oct 1, 2004 | 09:46 PM
GreenDemon's Avatar
Re: Oil LEak?
You can see it around the headlights? If that's oil, you have a serious problem. Try wiping the engine down, and then running it for a few seconds to locate the leak. I would say spray it with degreaser but then your opti might take a dump
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
