Oil in Intake Manifold
Old Oct 19, 2003 | 12:07 PM
Grover's Avatar
I was replacing my air filter today and just happened to look in the intake manifold and noticed that it had a nice coating of oil inside. It doesn't seem like there should be oil in the intake manifold, is this the sign of something bad?
Old Oct 19, 2003 | 12:21 PM
Teal96TA's Avatar
This may not be it, BUT I would imagine its from that line that goes from the passenger side valve cover and runs up to the throttlebody. I believe its part of the PCV system. If you take off the plate on top of the throttlebody you'll probably find it in there too... I removed the plastic elbow coming out of the valve cover and replaced with a breather filter and I'm assuming it keeps it back because the car has run better ever since! Its in a thread on here if you want the part number....whoever figured it out rules!
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
