Oil in intake
Old Nov 16, 2003 | 11:25 PM
Schurters LT1's Avatar
Question Oil in intake
the last time i was on the dyno when we let of the gas at the end of the pull i would have a puff of blue smoke ? so put the car away and i just took the intake off to do some work , tb is all black ,intake is all black and head intake side is black from oil. Now the P/S of the car the air tube from the v cover to the tb has oil in it Am i sucking up oil under load, should i put a pcvale in there or go to a air breather or somthing.
I am lost to why i am sucking in oil at the intake
anyone any input woulds be great
thx
Old Nov 16, 2003 | 11:35 PM
A couple of possibilities... 1) the PCV valve is plugged and not clearing the crankcase, or 2) you have excessive blowby on the rings and there is more vapor in the crankcase than the PCV system can handle. Either of these will cause the flow in the vent line to reverse. It is supposed to supply air from a port in front of the TB blades to the passenger side valve cover. But if the PCV system can't handle the load, the pressure will relieve out that line, and usually carry oil droplets into the line, into the top of the TB (check under the cover plate) and into the inlet air stream.
Old Nov 17, 2003 | 06:18 AM
Ya i am pulling of the tb today and haveing a look, I can't see rings the car only has 60,000km on it . Is the oe pcv system, strong enougf to do this job or should i up gread to somthing.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
