Oil In Hose Going To Throttle Body.
Old Jan 27, 2004 | 12:23 AM
  #76
Devil.Dog's Avatar
There's no ball or any other moving parts. Just a filter inside directly below the fitting. But it is a glass trap with a bleed at the bottom to let the water out.
Hmmm? Does anyone know what the pressure of the "metered air" is in the system?
Old May 25, 2006 | 08:00 PM
  #77
Silver's Avatar
Re: Oil In Hose Going To Throttle Body.
Originally Posted by PGR
For example, adding an inline filter to the passenger-side breather might reduce the amount of oil entering the TB, but it also might reduce the amount of blowby purged during WOT. Also, depending on where it is mounted, it may prevent oil from draining back into the valve cover. I haven't looked at the filters mentioned above, but a better solution might be a vapor separator - basically an inline cannister with no resistance that allows the oil to collect and drain back to the valve cover. I've seen these used on the 240Z's when autocrossed - apparently they suck a lot of oil through thier breather.
I'd like Injuneer's thoughts on this... if he felt so inclined...
Old May 25, 2006 | 09:29 PM
  #78
j071752's Avatar
My son's 97 LT1 with about 125K on a stock motor has a significant amount of oil at the front of the TB going into the passage mentioned.
We replaced the PCV valve but it seems to be worse 10K later. Can someone explain what is causing all this oil to go to the TB and how to remedy it.
Old May 25, 2006 | 11:34 PM
  #79
TobyZ28's Avatar
On top of the TB there is a black plastic rectangle attached with 6 torx bolts (i think). The rubber gasket (which I was quite sure was stock) on my car had deteriorated and actually expanded to 1.5 times its normal size! It was actually rippled around the edges because it was so big now. This caused some of the rubber to flop down into the cavity (where that tube connects) and block the passage. This caused oil to get stuck in the tube on my car. I made a new gasket with cardboard... and whaddya know.. no more oil getting sucked up
Old May 26, 2006 | 07:13 AM
  #80
Z28_95RIDE's Avatar
To each their own but I wouldn't use a cardboard gasket there for fear of deterioration, ingesting and plugging. Paper products are more abrasive than one might think. I can't blame anyone for wanting to fabricate this gasket because replacement comes as a kit and makes for a modestly expensive gasket repair. I saw this gasket as a little unusual in that it almost looked like a bladder of sorts. BTW, mine did just as you stated. It ballooned out incredibly. I think it was from the cleaner I had used on the TB when I did an intake leak repair.
Old May 26, 2006 | 09:20 PM
  #81
TobyZ28's Avatar
Yea that would be my guess too. I figured A gasket was better than no gasket. Its only a bandaid solution I live on my own and wasnt expecting to replace that gasket. The cardboard used was a very thing
solid type. Not the spongy cardboard either...
Peytons'z
May 6, 2021 09:25 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
lt1-xjs
Jan 17, 2015 07:52 PM
crazypurgatory
Jan 12, 2015 10:45 PM
RedRider81
Aug 31, 2002 06:13 PM
