Oil gage freaking out
Old May 30, 2004 | 12:42 AM
vin1382's Avatar
For the past few times that ive been driving my 93 auto firehawk, ive noticed when im just cruising and if i let off the gas, the oil gage starts going up and down randomly and pretty quick. same thing if i stop at a light or something. when i hit the gas again, the pressure returns back to normal. any ideas what this is? I have a 96 T/A with a 6 speed and it has never done this.
Old May 30, 2004 | 01:02 AM
Kryckter's Avatar
One thing to notice is if it does it under braking. If you apply the brakes really hard? Does the pressure fall down. If so that would be a fallen off pick-up tube in the motor and something that needs to be fixed. See if that is the case. If not , maybe a bad sending unit or a short in the wire somewhere. Are you full on oil? Sounds dumb but check the obvious first
Old May 30, 2004 | 01:17 AM
Cam94Z28's Avatar
My Fuel Gauge started doing that until it decided to peg itself all the way past full and stay there. The gauge could just be going bad.
Old May 30, 2004 | 09:45 AM
Hawk's Avatar
what I would do ASAP is do get a cheap machanical oil pressure guage and hook it up where the stock electric oil pressure guage sender is. Then I'd drive it to see if it's really the oil pressure thats screwy or your electric guage and sender has messed up. You need to do this to find out though if there is really a oil pressure problem, if so get it fixed ASAP.
Brian
Old May 30, 2004 | 12:45 PM
Just a thought, if your gauge started this recently and you got gas at a Shell station in Florida...hope you are aware of the news about the high sulfur gas that is taking out peoples gas sending units in the tank.
Old May 30, 2004 | 01:05 PM
Cam94Z28's Avatar
shoebox,
I actually never buy gas at shell. Are there any other stations that use the same gas?
Old May 30, 2004 | 01:36 PM
shoebox,
I would suppose that it could be sold under other independent station names. I would be trying to find out if you think you might have been a victim.
Old May 30, 2004 | 03:03 PM
Cam94Z28's Avatar
shoebox,
It happened immediately after i ran out of gas. When i finally added some gas and started my car, the gauge was going crazy, and eventually pegged itself past Full. It could have had something to do with the gas can I used, but it was pretty clean.
Where exactly is the sending unit, and how hard is it to replace?
Old May 30, 2004 | 03:08 PM
shoebox,
The sending unit is part of the pump assy that is inside the gas tank. I believe that Shell is going to have to pay for a bunch of replacements. The high sulfur corrodes/ruins the contacts on the unit.
Old May 30, 2004 | 03:13 PM
Cam94Z28's Avatar
I think I'll start buying my gas at Shell so I can get mine replaced for free
realistyc
Jul 28, 2015 07:32 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
