Oil Filter question
Old May 31, 2003 | 02:37 PM
KCFormula's Avatar
Oil Filter question
A few months back I put some FLP longtubes on my car. I really dont like too much about them but that is a different story.
Anyway, the collector sits right under my oil filter and IMHO it is too hot to be there. I have been changing my oil about ever 1500 miles with Mobil 1 because I am so worried. Should I be worried? If so what can I do? (Make a heat sheild of some sort?) The collector is close enough to the filter that I can not run the long filter. (maybe 3 inches) Should I be running a high temp oil filter?
Does anyone else see this as a problem?
Old May 31, 2003 | 04:28 PM
KCFormula's Avatar
Please don't everyone answer at once now.
Old May 31, 2003 | 04:45 PM
thewinner's Avatar
Damn 1500 miles on mobil1?!?! You must be rich! I wouldn't think its too much to worry about, look at all the people with FLP headers, i nver hear of any problems.
Old May 31, 2003 | 04:50 PM
Bud M's Avatar
I don't understand why you can't use the longer filters if you have 3 inches of clearance since the longer filter is only about an inch longer. I've never heard of a high temp oil filter, but from your description a heat shield sounds like a good idea. Assuming you have the factory oil cooler I would expect you will be okay as far as oil temps, but a heat shield can only help IMO.
Old May 31, 2003 | 05:18 PM
KCFormula's Avatar
Winner- I hardly drive my car. I have only changed the oil twice in 8 months. Once when I put the headers on because I had to remove the oil cooler.
Bud- I had to take the oil cooler off to get the FLPs on. I think there is actually a lot less than 3 inches of space but I tried to give you guys the idea that it isnt a whole lot. I will get under there sometime and take a pic. It may be more like 1 in in some spots.
Old May 31, 2003 | 06:12 PM
Bud M's Avatar
A picture would help but it shouldn't be so hard to fab up a heat shield that you could clamp to the oil filter.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
