Oil drain plug gaskets assorted
Old Nov 17, 2020 | 05:27 PM
94Z28LS1toLT1's Avatar
Hey guys I'm doing my oil change for my 1994 camaro z28 lt1 motor. And the guy at autozone gave me these I'll post the picture he recommended me use the 3rd one. Is the 3rd one ok bcuz my old gasket is the 2nd one. Thank u guys
Old Nov 19, 2020 | 09:22 AM
Chimera96's Avatar
Re: Oil drain plug gaskets assorted
the 3rd one is like stock....
Old Nov 19, 2020 | 11:30 AM
Long time since I've changed the oil, but I thought the stock drain plug had a white nylon gasket that was "attached", and did not typically require replacement. Memory is not what it used to be, though.
Should not be a critical issue.
Actually found an old photo of the factory plug. It has been drilled and tapped to add an oil temperature sensor, but it's the same plug that came on the car when I bought it new in 1994.
Old Nov 24, 2020 | 07:11 PM
Thank you guys. Now will the others work for the drain plug too. Or do I just save em in case I need them for something else.
Old Dec 21, 2020 | 10:45 PM
97 6SPEED Z's Avatar
Thumbs up Re: Oil drain plug gaskets assorted
Don't know about the other drain plug gaskets, but, the third one is called a "Seal-Tight" washer, and ..... it also works on the cross over coolant lines on the back of our cylinder heads too!
MTBSully
Jul 29, 2008 08:55 PM
Garcia95
V6 Tech
Jul 2, 2008 09:54 AM
guest74777
Feb 19, 2008 04:08 PM
SILVERZZ28
Advanced Tech
Jul 20, 2003 02:12 PM
SSnakeEater
May 13, 2003 02:06 AM
