oil dipstick tube
Old Nov 18, 2015 | 06:32 AM
frankrizz's Avatar
oil dipstick tube
Hey Members,
Just recently had car running with oil dipstick removed. It looked
like a volcano erupting with oil spurting out. Is this normal? Is there that
much pressure in the pan to make that happen? Also how difficult is it to
remove the tube from the block and reseal it. I noticed a leak from the
inlet to the block.
Old Nov 18, 2015 | 09:33 AM
Re: oil dipstick tube
I'd say it was normal, seeing that you have a hole in the block next to a crankshaft that is spinning and slinging oil. It's not pressure.
One bolt secures the dipstick and it is a friction fit into the hole in the block. Putting the tube in the freezer might make it easier to install. You can use a little RTV, if it has a sealing problem. If the end of the tube going into the block is bent or out of round, installation will be more difficult. A new tube might be advisable in some cases.
Old Nov 21, 2015 | 05:50 AM
97WS6SCharged's Avatar
I used a Lokar tube for a later model small block on my last LT1 and it was well worth the investment.
Nickster 7
May 1, 2015 09:04 PM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 10:30 PM
Jlo
Feb 23, 2015 12:20 PM
artic94
Jan 17, 2015 11:19 AM
