Oil Dipstick Pull It? Help Please
Old Mar 14, 2004 | 07:56 AM
Kataklysm's Avatar
I should have both headers out of the car today, other then the few bolts on the #8 cylinder the dipstick it whats getting in the way. I took off the bolt that holds it to the block, to get it completely out do I just pull it from up top? Is there something that I'm missing?
Old Mar 14, 2004 | 08:12 AM
Pull straight up and don't bend it. You might need to twist it a little. Only the bolt you took out secures it.
Old Mar 14, 2004 | 08:36 AM
Kataklysm's Avatar
Thank you, this install is a pain.
Old Mar 14, 2004 | 08:56 AM
Projectz28's Avatar
Moderator
That 1 bolt is all that secures it. But it doesnt come out very easy. Just be patient with it and it will come out. I have always found it easier to push it out. Laying under the car, grab hold of the tube and push/twist up till it pops out. The bottom portion of the tube is very long. About 6" of the tube is in the block below the hole. Going back in is a real pain. I usually just cut 3-4 inches of the tube off to get it back in easier.
Old Mar 14, 2004 | 10:06 AM
ibanez6rg's Avatar
Be careful, the second I pulled mine out it broke.
Old Mar 14, 2004 | 10:13 AM
Hyperspeed97z28's Avatar
I never bolted mine back in...
Couldnt get it that extra 1/8 of an inch in.. Been fine for a year no with no leaks...
Old Mar 14, 2004 | 10:16 AM
ibanez6rg's Avatar
I think thats why mine broke the second time... I pretty much raped it, getting it back in right.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
jmadoll
Mar 3, 2015 10:16 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
