Oil Cooler, Where is it? and what is it?
Old Jan 26, 2004 | 03:47 PM
Xride's Avatar
I was looking at the SLP page with teh SS options on it and one is "Oil Cooler"
Where do I find this? and on a M6 Car what does it do??
Old Jan 26, 2004 | 05:20 PM
442olds's Avatar
The oil cooler is a sandwhich type cooler which is is between the oil filter and the block. It sticks down about 2.5 inches and has two aluminum lines running to it. These lines run along the oil pan and one connects to the water pump and one connects to the radiator. Its basically a small radiator and the water from the engine flows through it and the oil flow around the outside of the fins. The only reason they put it on some cars was to ward off high under hood temps. I don't remember what actually deteremined which cars got it. But I think Z rated tires was a factor.
Old Jan 26, 2004 | 05:27 PM
Oil cooler.
Old Jan 26, 2004 | 07:38 PM
Xride's Avatar
hmm thank you, I jsut noticed that it was a $400 SLP option installed on the car.
Do you think its worth taking off to put on my new SS?
Old Jan 26, 2004 | 08:09 PM
It's not known to be an effective cooler (compared to other types) and also prone to problems that can lead to coolant contaminaion of the oil. A lot of people that have had them, have removed them. Would I put one like that on my car? No.
Old Jan 27, 2004 | 10:21 AM
JohnD's Avatar
Just to look at the other side of things, I went to a lot of trouble to find an oil cooler for my car and I'm happy with it. That being said, I don't use it in competition and it gets really hot here in the summer. If I raced my car, I wouldn't be using an oil cooler or a paper filter.
Old Jan 27, 2004 | 10:30 AM
I'm really not sure how the stock oil cooler got such a bad rap. The one on my Formula has a sticker indicating it is made by Moroso. Never had a problem with it in the first 65K miles of operation, it was in good shape and clean when we pulled the engine for the stroker build, and the shop that built my engine had no issues with reusing it.
Oil cooler
Old Jan 27, 2004 | 10:19 PM
Xride's Avatar
hmm, maybe I'll take it off then, just in case.
suppose its going to make a mess too isnt it.
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
