Oil Cooler seal?
Old Jan 14, 2005 | 02:50 PM
BoobSter-lt1-z's Avatar
Oil Cooler seal?
I have a leak coming from what seems to be the oil cooler rubber seal. I am going to have the seal replaced soon but I was wondering If I will see Oil pressure gain after this seal is replaced?
Old Jan 16, 2005 | 05:12 PM
Re: Oil Cooler seal?
Ttt?
Old Jan 17, 2005 | 09:37 AM
OBE1 95Z28's Avatar
Are you sure it's an oil cooler? I thought only manual transmission pre-96 F-Bodies came with the oil cooler option?
Old Jan 17, 2005 | 10:04 AM
flusz28's Avatar
oil cooler was a order option for 94-97 auto or manual - i had one on my 94 z28 with a auto stock. i removed it though.
Old Jan 17, 2005 | 12:47 PM
Cman's Avatar
Probably not enough to really notice anything on the stk gauge, with a proper o/p gauge you might see a slight increase.
I wouldn't wait too long to get that fixed, that leak could cause a bigger problem if the seal decides to finally let go. Take care of it pronto.
Tony
Old Jan 17, 2005 | 03:51 PM
Loadre's Avatar
Werd.
Old Jan 28, 2005 | 04:22 PM
Sorry for the old response...
I still have dial up and its frustrating because its so slow and I have to wait for it to load so I do other things meanwhile and next thing you know i forgot I was using the internet...almost like racing a LIL CIVIC
But yeah..I dont want it to blow out on me all of a sudden so Ill get this changed as soon as the cash flow comes in and ill let you guys know if there is any improvement if any
tHanks!
Old Feb 7, 2005 | 02:43 PM
By the way,
What filter would I use if I remove the Oil Cooler?
What are the steps in removing the oil cooler?
Thanks!
dylan1303
May 22, 2015 12:24 PM
KYWes
May 15, 2015 09:10 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
97 RedSS
Jun 10, 2003 07:58 PM
