Oil cooler question
Old Sep 16, 2004 | 11:24 AM
All4Chevy's Avatar
Oil cooler question
Just wondering what my oil cooler is supposed to be attached to/with.....right now it is zip tied to some piece of metal under my car and it keeps sagging down a little bit. It looks like the only way to get it to stay in place is to try and drill a hole in my car and bolt it...but that will be very tough to do. A hose clamp will not fit, as the way it is now anyways. Any suggestions?
Bill
Old Sep 16, 2004 | 01:21 PM
Loadre's Avatar
Re: Oil cooler question
Don't know exactly what part is sagging but after it comes out of the cooler above the oil filter the two lines run together up alongside the motor and are held together by a clamp that has provision for one of the oil pan bolts to bolt it down. The rubber hoses should run straight to the radiator.
Old Sep 16, 2004 | 02:12 PM
All4Chevy's Avatar
Oh...well mine runs out of the oil filter backwards under the middle of the car and the oil cooler radiator is under my back seats, under my car. Facing lengthwise with the car....so the air hits it from the sides or something. But the oil cooler radiator is just hangin by some tie wraps.
Bill
Old Sep 16, 2004 | 02:22 PM
Loadre's Avatar
Bill
WTF? That isn't factory.
Old Sep 16, 2004 | 07:42 PM
Jon A's Avatar
If you want it to do some good, move it here:
http://www.jonaadland.com/Z28/Mods/O...lerMounted.JPG
Not only will it be rather ineffective under the car, but you run the danger of road debris damaging it and/or the lines which will ruin your engine unless you happen to catch the loss of pressure the moment it happens.
I attached mine for now with the quick connects that come with some coolers and are available at most autoparts stores. I plan on a more secure bracket but haven't gotten around to it yet.
Do you roadrace? If not, you probably don't need the cooler anyway and could simply remove it.
Old Sep 16, 2004 | 10:14 PM
All4Chevy's Avatar
I used to race...but I don't anymore. I don't really get on it much at all....but the local mechanic said since teh car runs so hot its better to leave it on there than to take it off.
I figure it can only help...assuming it doesnt spring a leak. It's pretty well up there not to hit any debris...and since the front of my car is only about 1.5 inches from the ground (the air dam) I don't go over anything big anyways.
Bill
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97 RedSS
Jun 10, 2003 07:58 PM
Camaro90RS
Jul 23, 2002 07:57 AM
