oil cooler leaking
Old Apr 27, 2004 | 06:31 PM
jj93z28's Avatar
oil cooler leaking
Is it possible to check an oil cooler for leaks..... I ask because I have been getting a massive amount of coolant flowing into the oil after my camswap. I was twisting and turning the metal hoses to the cooler to get to the oil pan bolts, I figured I may have damaged something inside. How do you get the cooler off? Thanks
Old Apr 27, 2004 | 11:04 PM
philcam01's Avatar
take the oil filter off and pressure test the cooling system, if it leaks you should see the coolant drip
Old Apr 28, 2004 | 09:25 AM
BUBBA's Avatar
When you get the cooler off, I'd leave it off. JMHO.
Old Apr 29, 2004 | 05:58 AM
jj93z28's Avatar
You can leave it off??? are there any parts necesary to do this other than finding a way to cannect the two coolant lines?
Old May 26, 2004 | 01:02 PM
jj93z28's Avatar
So can I just take it off? Will the oil filter just screw in where the oil cooler used to be?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
