Oil cooler
Old Jul 13, 2013 | 10:11 PM
Shangrila's Avatar
Oil cooler
Does anyone have a diagram of the inner workings of the oil cooler in a 95 z28?
Old Jul 13, 2013 | 10:17 PM
SSSean's Avatar
Re: Oil cooler
http://shbox.com/1/oil_cooler.jpg
Old Jul 13, 2013 | 11:11 PM
Shangrila's Avatar
Re: Oil cooler
Originally Posted by SSSean
Thanks, but I was looking for an actual diagram of #4 in the pic. I have a feeling mine is cracked as I was having issues with it before re-installing it.
Old Jul 14, 2013 | 01:00 AM
Dan93z28's Avatar
Re: Oil cooler
Just throwing this out there.
I deleted mine and have been running 5-40w synthetic in it for 3 years with no problems. From my understanding the cooler was to prevent conventional oils from thinning out too much.
Now that's just what I've read, searching various forums, so do so at your own risk. You will need a replacement coolant hose which costs a few bucks but the thing does weigh a few pounds though if you've got the weight reduction bug.
Old Jul 14, 2013 | 01:40 AM
OBE1 95Z28's Avatar
Re: Oil cooler
It's my understanding that it more of a oil heater (when the engine is cold) than an oil cooler. It helps to get the oil up to operating temperature quicker.
Old Jul 14, 2013 | 08:45 AM
Shangrila's Avatar
Re: Oil cooler
I think it's a dual purpose item @ the poster above, I thought factory recommends using 5w30 and tolerances in the engine determine what thickness to use? Anyways, at first it was leaking oil bad by the filter or so it seemed, thought it was the oil filter so that probably got over tightened and ended up replacing it. Then noticed it was at the joint where the coolant pipes connect, used sealant around the coolant pipes connection that has the crossover pipe type seals on, it that took care of the issue for a while. It has a new head gasket and I just changed plugs and they were all clean, engine oil clean, cylinders were clean and there is no performance issues. Does anyone make a dual filter conversion kit for these engines and is it okay to put the filters in the engine bay upside down for easy changing?
Old Jul 14, 2013 | 02:13 PM
RamAir95TA's Avatar
Re: Oil cooler
They are retarded and don't work for crap. Most people delete them. Hell GM did away with them halfway through the LT1 f-body's run. 95+ cars didn't even have them as an option.
Old Jul 14, 2013 | 02:44 PM
Shangrila's Avatar
Re: Oil cooler
Anyone still make the bypass hose gm#10197675 or gates #18959?
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
