Oil Change Problem
Old Feb 11, 2004 | 05:20 PM
96HealyZ28's Avatar
Oil Change Problem
I got a 96 z28. Ok, yesterday, I got a standard oil change. I had a small, small oil leak before, one that never hit the ground and would only smell like burnt oil when I pushed it a little bit. But yesterday after I got my car back, I took it on the freeway and when I got off at a red light, I smelled oil bad. I pulled over and popped the hood and it was smoking. I pulled my car forward and saw that oil was dripping on the ground. I thought that i could have been extra oil that spilled during the change but it is still dripping now. What could have happened during a routine oil change to make this happen. I am taking it back tomorrow but I can't imagine what happened. Any ideas?
Old Feb 11, 2004 | 05:24 PM
Heaven only knows. That's why I change my own.
Old Feb 11, 2004 | 05:26 PM
96HealyZ28's Avatar
LOL, thanks shoebox
Old Feb 11, 2004 | 05:51 PM
96ZRDR's Avatar
Check your oil level first, then make sure that drain plug is on tight. Check your oil filter too, tight but not too tight, and make sure it is not abused.
Old Feb 11, 2004 | 06:02 PM
96HealyZ28's Avatar
Oil level was a little high when i got it, checked filter, it was nice and clean, havnt checked the drain plug. will do that.
Old Feb 11, 2004 | 06:16 PM
Kataklysm's Avatar
Only thing it could be is the filter gasket leaking or the plug isn't in all the way...or something could have punctured the filter.
PCLZ28
Dec 24, 2015 05:19 PM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
