Oil?
Old Sep 13, 2004 | 09:21 PM
ChrisUlrich's Avatar
Oil?
How many quarts go into my LT1? What do you guys recommend? I hear that purple crap is awesome. 5w 10 goes in it right?
Old Sep 13, 2004 | 10:02 PM
Fuels94TA's Avatar
Re: Oil?
5 qt. with a standard size oil filter, 5 1/2 qt with a larger oil filter.
Old Sep 14, 2004 | 06:26 AM
Re: Oil?
5W 10 right?
Old Sep 14, 2004 | 08:51 AM
MarkyMark's Avatar
Re: Oil?
5w 30 or 10w 30
Old Sep 14, 2004 | 09:08 AM
Kataklysm's Avatar
Re: Oil?
The cars are recommended to use 5w30. Personally I'd use synthetic.
Old Sep 14, 2004 | 11:01 AM
LameRandomName's Avatar
Re: Oil?
I have an LT1 in a B-Body, and I use 4 quarts.
It's more than enough to keep the pickup covered in normal driving and in drag racing, and it gets the oil away from the crank more.
It also, oddly enough, actually registers as within the normal range on the dipstick.
BTW, I personally use 10w-40 Amsoil.
The reason for the 10, instead of 5, is because it's an older engine with about 140,000 miles on it, and 5w oil will allow the pressure to come down lower than I am comfortable with. You can DEFINITELY get away with less oil pressure when using synthetic, because of the different characteristics of the oil, but I still like to see at least 10lbs at idle, when hot.
Old Sep 14, 2004 | 11:38 AM
FastZinTennessee's Avatar
Re: Oil?
5 quarts, I use Mobil 1 10w30. The 5w30 was a little thin, and I didn't like the low oil pressure at idle.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
