ohm's of my injectors?
Old May 8, 2003 | 04:27 PM
Smokn '94 Z's Avatar
Question ohm's of my injectors?
I am wondering what my injectors should ohm. My car is a '94Z & it still has the stock injectors which I believe are 24# injectors. Is there a # they should read or if they are all the same then that is the #?
Eddie
Old May 8, 2003 | 04:35 PM
Dr.Mudge's Avatar
They should all read "the same" or darn close, if one or more are off they could be bad or on thier way out. Stockers are high impedance and you must stick with them if you dont run a dropping resistor, injectors should be around 12 OHM I believe, someone else will post I'm sure.
Old May 8, 2003 | 04:50 PM
madwolf's Avatar
All good and working stock injectors I've measured were either 12.5 or 12.6 Ohms. Bad ones also measured 12.5. (which means they were just plugged with crap but the coil was still good)
Old May 8, 2003 | 09:05 PM
Thumbs up
Thank you....
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
9
Sep 20, 2015 11:23 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
