Quick Mac header and offroad pipe install question
Old May 8, 2003 | 07:28 PM
TLyden316's Avatar
Question Quick Mac header and offroad pipe install question
Do I have to buy another flange to weld to the y-pipe to connect the offroad pipe? Basically, what extra parts or welding is required? I have these coming in the mail and I need to know. Thanks again.
Old May 8, 2003 | 07:41 PM
Jon97Z's Avatar
Um, unless I'm reading this wrong, the offroad pipe and the y-pipe are the same thing. Hence the name off-road y-yipe.
Old May 8, 2003 | 07:44 PM
TLyden316's Avatar
I forgot to mention, its for a 95 single-cat Z28. It's different from a 96-up...the y-pipe and offroad pipe are two different things.
Old May 8, 2003 | 08:48 PM
mineralwater's Avatar
on a 95, the y-pipe and offroad pipe are different things.
Your y-pipe should bolt up to the offroad pipe no problem, if you got the mac ypipe with mac offroad pipe. nothing else needed.
the only time you'd need the starter flange it comes with, is if you cut off your existing cat from the old y-pipe and want to bolt it into your mac y-pipe.
but from the sounds of it, you won't need to buy anything else, the offroad pipe is just a direct bolt-in.
Old May 8, 2003 | 09:06 PM
mobleman's Avatar
the off road pipe takes the place of the catalytic converter. The y-pipe is the y-pipe
No need to weld, same setup I have, everything just bolts together.
Burn_Out
Aug 18, 2002 08:49 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
